It is currently Sat Aug 23, 2025 3:53 am
PostPosted: Wed Jun 05, 2013 9:47 pm
First name: Wendy
Last Name: W
State: Arizona
I'm confused. I have used 1/4 sawn for neck blanks and stacked heels, but this time my neck is flatsawn birdseye maple. What grain direction should the heel stacks be? This will be a Spanish style heel with slots for the sides. Can I use flatsawn pieces of the same birdseye stock as the neck for building up the heel?
Thanks, Wendy
PostPosted: Thu Jun 06, 2013 6:20 am
First name: Jim
Last Name: Kirby
I suspect it will look funny if you switch the grain orientation between the neck and heel stack? I'd stick with the flatsawn orientation.
Maple neck with a Spanish heel? Sounds like an interesting project.
Jim Kirby
kirby@udel.edu
PostPosted: Thu Jun 06, 2013 9:04 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I would stack all of the pieces in the same grain order. It blends together nicely, visually, and all of the wood movement will be consistent.
http://redrivercanoe.ca/
PostPosted: Thu Jun 06, 2013 9:43 am
First name: Wendy
Last Name: W
State: Arizona
Thanks Doug and Jim, that's what I wanted to hear.
PostPosted: Thu Jun 06, 2013 10:06 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
So, then you already knew the answer! You're smarter than you think.
PostPosted: Thu Jun 06, 2013 10:18 am
First name: Wendy
Last Name: W
State: Arizona
So do you think there is a problem using flatsawn for a spanish heel? I have my heart set on birdseye maple and all I can find is flatsawn or riftsawn that I already have, but have decided not to use.
PostPosted: Thu Jun 06, 2013 11:13 am
That's Ok, I'll take them off your hands. laughing6-hehe
PostPosted: Thu Jun 06, 2013 12:38 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I have never done a Spanish heel, so someone may come by and tell you why this won't work. . . I would consider laminating the neck blank with a center strip and have the flatsawn edge on the sides of the neck. You then would have no heel stack at all and the birdseye figure would show most on the sides of the neck and heel. Just thinking out loud. . .
Bryan Bear PMoMC
PostPosted: Thu Jun 06, 2013 2:13 pm
First name: Jim
Last Name: Kirby
Mechanically, I don't think there is a problem with the spanish heel and flatsawn orientation. I've never used birdseye - I'd have to defer to Bryan on which orientation is the right one visually - no clue here.
Jim Kirby
kirby@udel.edu
PostPosted: Thu Jun 06, 2013 2:44 pm
Visually there isn't a right or wrong. Hard going carving a Neck/heel out of birds eye, you have my sympathy.
PostPosted: Thu Jun 06, 2013 3:07 pm
Birds eyes mostly show on the flat sawn side, so that orientation would be best visually. Flat sawn should pose no problem with stability because hard maple is plenty strong for nylon strings. Carving a neck from birds eye maple is not much harder than anything else. I did about a half dozen from it and the only thing to be cautious about is using a handplane because it can chip out the eye if your not careful.
PostPosted: Thu Jun 06, 2013 3:53 pm
You've obviously never done Cedrela then. There's a world of difference! Cedrela carves itself.
